Trunk mount battery old MOPAR ??
  • 69chargermd
  • 69chargermd's Avatar Topic Author
3 years 8 months ago #60192 by 69chargermd
Trunk mount battery old MOPAR ?? was created by 69chargermd
Battery is currently in the trunk. Positive cable runs from battery to starter lug.
Concerned about having hot cable running length of the car at all times.
What can be done to address this ?
Some type of solenoid set up in the trunk so that cable is hot only during cranking ?
Any help in how to wire this type of setup ?
Thanks.
(Ps; electrical knowledge is limited). Thx
3 years 8 months ago #60198 by Noah
Replied by Noah on topic Trunk mount battery old MOPAR ??
Nice garage! I'm pretty sure today's chargers and challengers put the battery back there.
I'm not aware of any isolation device used by OE's that have the battery in the rear of the vehicle from the factory.
I have seen "racecars" with a big old manual ON-OFF switch somewhere around the rear bumper, trunk pan area. If I was worried about the power wire running under my car, that's probably what I would use.
  • 69chargermd
3 years 8 months ago #60207 by 69chargermd
Replied by 69chargermd on topic Trunk mount battery old MOPAR ??
Thx Noah. I have seen kill switch’s or on off switch’s on race applications. I probably need to look into that.
Was curious what all is intailed in that type of install.
3 years 8 months ago #60209 by Matt T
Replied by Matt T on topic Trunk mount battery old MOPAR ??
Battery disconnect switch is the cheap and easy way to do what you want. They attach to the battery neutral post.
www.harborfreight.com/battery-disconnect...ry+disconnect+switch
