can bus
  • Jesse c
  • Jesse c's Avatar Topic Author
3 years 8 months ago #60063 by Jesse c
can bus was created by Jesse c
would like some opinions on this can bus capture as this is new to me. i have no communication with the engine ecu from the cab diagnostic plug but can communicate while back probing at the ecm. I have no drivability problems just communication fault on dash. truck has left workshop for the time being and i was hoping i could get some opinions on this so i can diagnose it next time its in. please let me know if the attachment doesn't work, I haven't tried it before on here.
3 years 8 months ago - 3 years 8 months ago #60064 by juergen.scholl
Replied by juergen.scholl on topic can bus
The CAN low signal level seems to idle at 5 V instead of 2.5V. Most of the time the signal is pulled down to ground, only a small fraction shows an adequate voltage drop of ~1V. The CAN high recessive voltage level should be close to 2.5V, yours seems to be slightly above ground voltage and again the peak to peak voltage on the signal is almost 4V instead of one volt
Then again, it seems to be a Hantek scope with a long time base selected surpassing the capabilities of the tool.
Last edit: 3 years 8 months ago by juergen.scholl.
  • Jesse c
3 years 8 months ago #60065 by Jesse c
Replied by Jesse c on topic can bus
Okay I see what you mean, so getting another capture of this at another time base would be my first step I’m guessing. So what time base would you suggest I try and also are you thinking it could be a hantek issue?
3 years 8 months ago #60066 by juergen.scholl
The Hantek isn't too much of a help here but the main problem seems to be the voltage levels. This wouldn't be a Hantek issue though.
  • Jesse c
3 years 8 months ago #60067 by Jesse c
Alright thank you for your help, one last question have you seen this before and what did you find that caused it.
3 years 8 months ago #60068 by Matt T
Replied by Matt T on topic can bus
The capture does look a little strange. Was it taken at the DLC or ECM? And what were you using for the scope ground?
Anyways a message on the cluster and no comm with the ECM at the DLC ain't much of a starting point. Scan the entire vehicle at the DLC to see what modules are visible and what codes they're setting. Then maybe rescan backprobed at the ECM. Those tests coupled with, preferably O.E., network wiring diagrams should give you some direction.
  • Jesse c
3 years 8 months ago #60069 by Jesse c
Captured at the ecm and using chassis ground or block can’t remember. The code in the picture is in the vecu and becomes active while running, the other captures are at the dlc plug and cab ground was used.
3 years 8 months ago - 3 years 8 months ago #60070 by juergen.scholl
The second of the last 4 pictures shows correct voltage levels on both can signals if it was a high speed can network (and it doesn't seem to be, it's another protocol). Make sure your connections are ok or/and measure using just one channel across both can + and can-.
Last edit: 3 years 8 months ago by juergen.scholl. Reason: Notes
  • Jesse c
3 years 8 months ago #60071 by Jesse c
Okay thanks for your help very appreciated thank you.
3 years 8 months ago #60072 by Matt T
That explains why your first waveform looks off :silly: J1708 is a low speed, RS-485 based, protocol which your Hantek is fast enough to work with. Your first capture looks about right other than the one packet not getting pulled to ground properly. I'd check voltage drop between cab, chassis and engine grounds first. Modules sitting at different ground voltages could be the problem because although RS-485 is a "2-wire" network it also requires a common ground between modules.
  • Jesse c
3 years 8 months ago #60078 by Jesse c
Oh wow I didn’t realise that difference in protocol changed the way they looked on scope. Ok ground’s I will check, so those captures at the dlc really threw me and lacking confidence doesn’t help. Does j1708 have different voltage ranges compared to others like j1939 which is in a lot of trucks
  • Jesse c
3 years 8 months ago #60117 by Jesse c
Ok thank you I’ll try checking the grounds when I can
