95 Pontiac Transport SE over acceleration on start up
3 years 9 months ago #59334 by TL_1
I'm working on a 95 Pontiac Transport SE. I think this is a 3.1 v6. It's not mine, but I am helping a friend. When it's starts up the engine and tach immediately red line and engine revs to full throttle without touching the pedal. I had put in a new battery, which was not related to the problem, and a part store manager told be to disconnect the neg wire from the battery for at least 10 minutes, then try. I did this the first time for the whole ten minutes, no change, then I tried again, but not for the full ten minutes, but still no change. I was told to look at the throttle position sensor next. I haven't tested it yet but if anyone has experienced this issue before and was able to fix it, let me know. Thanks.
3 years 9 months ago #59337 by Noah
Being this is an old vehicle with a throttle cable, I would first pull the intake boot and look to see if the throttle body is jammed open, and if so inspect the cable and linkage.
The following user(s) said Thank You: TL_1
