Using DLC Pin 4 to Ground?
  • rockp2
  • rockp2's Avatar Topic Author
3 years 10 months ago #59292 by rockp2
Using DLC Pin 4 to Ground? was created by rockp2
98 Chevy Blazer 4.3L 4WD Vin "W"
This a theoretical question: To retrieve DLC codes for Transfer Case I know to Ground DLC Pin 13 which causes selector switch to flash codes. However everything I can find just states to connect pin 13 to reliable vehicle ground. I'm curious as why none state to Ground 13 to 4? Is their a reason this shouldn't be done? Or, is this a really dumb question?
3 years 10 months ago #59298 by Chad
Replied by Chad on topic Using DLC Pin 4 to Ground?
DLC pin 4 will work just fine, as long as it is a good ground. Pin 5 should work, too.
The following user(s) said Thank You: rockp2
