2001 express popping under high idle
  • Da Beginner
  • Da Beginner's Avatar Topic Author
3 years 11 months ago #58857 by Da Beginner
2001 express popping under high idle was created by Da Beginner
Okay still new to this so am reaching out for help, any help would be greatly appreciated.
So I’m working on a 2002 Chevy express 2500 with the 4.3 L35 motor. Had some issues with the timing. On the scan tool spark degrees reads 18 degrees, put a timing-light on it and it was reading around 18/ 19 degrees. Anyone knows what it should read? Should it be at 0 or close to it
Also when I put the van in Reverse it has a little bit of power, but when I switch to drive the power is low. When I step on the gas like around 2500 to 3000 rpm it makes a popping sound from the throttle body.
Is my timing off? I set it up with the number 1 cyl on the compression stroke and the distributor Rotor pointing at the little arrow. It starts and Idle fine
3 years 11 months ago #58869 by Cheryl
Replied by Cheryl on topic 2001 express popping under high idle
Better check fuel pressure. Popping through intake usually is a lean condition.
