2001 Silverado 12v on 5v reference
  • david.percefull
  • david.percefull's Avatar Topic Author
3 years 11 months ago #58673 by david.percefull
2001 Silverado 12v on 5v reference was created by david.percefull
I am showing 12v on my 5v reference testing at tps,rough idle reduce engine power dtc p1515
  • david.percefull
3 years 11 months ago #58689 by david.percefull
Replied by david.percefull on topic 2001 Silverado 12v on 5v reference
Now I have 5v on all references,may have miss read while probing new code of p 1516,still in instant limp without even starting engine though it will start
  • david.percefull
3 years 11 months ago #58703 by david.percefull
I have and I seem to have everything except the yellow tac motor wire I believe #8 or#16 at the module I'm not getting a pulse at key cycle I do on brown wire,I'm not sure if I'm suppose to,I believe it works through reversing polarity to open/close blade. Just trying to not replace a working module,i have continuity through harness,thanks for reply
  • david.percefull
3 years 11 months ago #58705 by david.percefull
Ok I definitely didn't get the pulse at key cycle on yellow like I did when probed to brown,this was while I was working off gm flow chart. I had checked open or short on harness using ect3000 and only used multimeter for continuity and voltage, I will definitely put the meter on it and check that way too,thanks for that but I think this is going to be a module too thanks so much
