2012 mithsubishi l200 triton wont start with the cam sensor pluged in
  • capochichi.abel
  • capochichi.abel's Avatar Topic Author
3 years 11 months ago #58605 by capochichi.abel
hi family good day to every one in here,i have 2012 mithsubishi triton l200 with 4d56 common rail engine it came in to the shop with diesel entry directly to the engine oil drain about 15liters of oil in the engine and also has injectors problem so i decide to take the problems one after the other the i replace the injectors but find it dificult to start the engine no fault code i normal fuel pressure on my live data on the process i dont what brougth me to unplug the fuelrail pressure sensor and the camshaft position sensor since they shared the same visible socket,and the car started,so i have to difrensiate were is my problem i tried to unplug only the cam sensor and the car start fine when replug the sensor the engine dies imidiatly i scope my timing was ok no fault code.could some one please help me to know what next?thanks
  • capochichi.abel
3 years 11 months ago #58609 by capochichi.abel
hi thanks for your income,yes i have 5v refrence and ground the signal wire also has bias voltage 5 volt when unplug.
  • capochichi.abel
3 years 11 months ago #58610 by capochichi.abel
oh sorry your quetion was if i loose the 5 volt refrence when its plug in,i didnt verify that i assumed beacaus i scope it and has my signer i didnt need to do that thanks i will double check that
  • capochichi.abel
3 years 11 months ago #58625 by capochichi.abel
When the cam sensor is connected the car won’t start but when I disconnect it the car can now start,and after it start and I reconnect the cam sensor the engine will short down immediately
  • capochichi.abel
3 years 11 months ago #58627 by capochichi.abel
Did you mean I should replace the cam sensor?
  • capochichi.abel
3 years 11 months ago #58628 by capochichi.abel
I swapped the cam sensor with the ckp sensor since they are using the same sensor but same problem
The following user(s) said Thank You: Leo94
  • capochichi.abel
3 years 11 months ago #58633 by capochichi.abel
i swaped the sensor itself not the socket,and then the same problem continue it couldnt start but has good wave form from both and the synchronization of the timing is correct but it wont start exept when i unplug the cam sensor before it start
  • capochichi.abel
3 years 11 months ago #58640 by capochichi.abel
Ok thanks then I will make order for it
3 years 11 months ago #58655 by Desmond6004
Cam timing could be out and the sensors are out of alignment which the ECU picks up when both are connected. When one is disconnected it ignores that sensor and simply runs on what it can see.
  • capochichi.abel
3 years 11 months ago #58674 by capochichi.abel
Hi families I have already scope the engine to check the timing is well synchronized
2 years 11 months ago #63444 by Ismail786
Hi did you manage to find a solution to this problem I seem to be having the exact same issue with my 2011 triton 2.5 did
1 year 5 months ago #90930 by Waldoventer
hey anyone found an answer for this problem?
