Nissan Thermostats
  • Saverauto
  • Saverauto's Avatar Topic Author
4 years 1 week ago #58567 by Saverauto
Nissan Thermostats was created by Saverauto
This is not a repair question but a question regarding the need for two thermostats in some Nissan engines.
The QR20DE, QR25DE (Nissan X-Trail & Murano) engines have two thermostats, both of which have different temperature ratings (82C & 96C).
I'm aware that some of the new Subaru vehicles have a secondary thermostat that controls the temperature of the transmission oil.
Any idea why Nissan uses two? It would be useful to know the reason so engine overheating (due to a faulty thermostat) can be diagnosed accurately.
Thanks...
4 years 1 week ago #58573 by Tutti57
Replied by Tutti57 on topic Nissan Thermostats
Hi Saverauto, it doesn't sound like those are US models, but this probably applies to those too, unless they're diesel motors.
They call it a two stage system, where the thermostat operates as a normal one, and the water control valve closes under 95*c to only let coolant flow through the head. Above 95*c and it opens and let's it flow through the block. The control is supposed to get the engine up to temp faster. The control valve has hoses going to the throttle body and the heater core. The thermostat is just from the block to the radiator.
Either stuck closed would cause an overheat. You'd know if the water valve was stuck closed if it is overheating, and the radiator inlet hose isn't hot. That would mean that the water is only going through the head, through a pipe off the valve, that would be hot, and it's not going through the block.
The following user(s) said Thank You: Saverauto
4 years 1 week ago #58577 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Nissan Thermostats
It is supposed to give better smoother control of runing temperture in a wide range extreme conditions. Longer ago than I care to remember when I was a young seagoing engineer it was used on small auxilary diesel engines ISTR Lister diesel but it might have been Petter.
A lot of manufacturers are now using weird and wonderful thermostat setups thesedays some of which work fine and some not so good.
