Any Citroen experts here, app sensor issue after injector prog (I’m from the UK)
- philreed52
4 years 2 weeks ago #58465
by philreed52
Any Citroen experts here, app sensor issue after injector prog (I’m from the UK) was created by philreed52
Hi everyone.
I’m from the UK so may be a long shot but I’m after some help with a Citroen c4. I’m struggling for a wiring diagram and pin out for the ecu. I need to test the accelerator pedal position as the vehicle is showing a faulty pedal after injector programming. I’ve fitted and programmed a new injector to cure a misfire but now have a faulty pedal. My concern is that the shorted injector has damaged the ecu. Will scope the pedal potentiometer to confirm it is ok but have fired the parts cannon and fitted a 2nd hand pedal (not confirmed good btw)
Thanks
Phil
Thanks
Phil
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 2 weeks ago #58471
by juergen.scholl
Replied by juergen.scholl on topic Any Citroen experts here, app sensor issue after injector prog (I’m from the UK)
You would have to tell us model year, engine/engine management system to get you the correct diagram, wouldn´t you?
- philreed52
4 years 2 weeks ago #58473
by philreed52
Replied by philreed52 on topic Any Citroen experts here, app sensor issue after injector prog (I’m from the UK)
My apologies
YF73D9HC8DJ809042
YR63 LZA
2013 Citroen C4 1.6 hdi
YF73D9HC8DJ809042
YR63 LZA
- juergen.scholl
4 years 1 week ago #58483
by juergen.scholl
- philreed52
4 years 1 week ago #58487
by philreed52
Thank you so much Jurgen, that will be a great help. I will scope it on Tuesday and post some waveforms of my results. I suspect the pedal to be faulty but at the moment I’m concerned that the shorted injector has damaged the ecu. Why the French cannot use colours for the loom I will never know….
- philreed52
4 years 1 week ago #58554
by philreed52
Following on from this, is the wiring diagram definitely right? It’s hard to tell as I can’t read the codes on the wiring at the pedal. I definitely have a short to positive and I think it’s inside the ecu
At the pedal I have pins
1 purple 9.7v
2 green 4.98v
3 cream colour 4.98v
4 grey 0.003v
5 red 9.74v
6 orange 1.103v
Pins 1&2 3&4 are twisted pairs
Why oh why are French wiring diagrams so poor
1 purple 9.7v
2 green 4.98v
4 grey 0.003v
5 red 9.74v
6 orange 1.103v
- philreed52
4 years 1 week ago #58558
by philreed52
I now have access to Haynes pro and the diagram is identical. Please don’t assume my PIN numbers are accurate as I was unable to identify the codes on them
