HELP! 1999 Ford Ranger 3.0L U vin, Flex fuel, misfire no codes
  • SimplyCircuits
  • SimplyCircuits's Avatar Topic Author
4 years 1 week ago #58523 by SimplyCircuits
Downstream disconnected and it’s the same.
4 years 1 week ago #58531 by Cheryl
You try resetting the keep alive memory after the things you’ve done to it so far?
  • SimplyCircuits
4 years 1 week ago #58539 by SimplyCircuits
I haven’t after every test early on. But I did after I isolated the intake from the brake booster and in between the past several tests. LTFT’s just slowly climb until they stabilize around 12-15. I’ll reset now and get trims at a higher idle.
  • SimplyCircuits
4 years 1 week ago - 4 years 1 week ago #58542 by SimplyCircuits
One note to add. After resetting trims when in OL the truck idles more rough. With load pct around 42. Then smooths out quite a bit once in CL, and load pct decreases to 37. Although I’m attributing that to the higher OL rpm, I thought I should mention it just in case. I’m erring on the side of posting too much info in hopes that something might ring a bell for one of you. Hopefully that’s not too annoying to the folks on here.
Ok. Not what I expected. At fairly steady 3000 rpm’s the LTFT’s are steady around zero. While the STFT’s both start off around zero to negative and fluctuate up as I hold it (30-45 seconds) until the STFT2 is bouncing off of 24. STFT1 is bouncing off of 18-19 I believe. Let off and they return to between 0 and -3. While LTFT’s return to LTFT1 13-14 and LTFT2 16-17.
Last edit: 4 years 1 week ago by SimplyCircuits.
4 years 1 week ago #58566 by al514
I have an 01 ranger that only leaks at the booster when pressing the pedal. And its an inside leak at the pedal. I happened to catch it one day. Thought it was a cool find. These trucks just don't like setting misfire codes. Mode 6 data helps
4 years 1 week ago #58578 by Andy.MacFadyen
Just catching up on this having been off for a while but have you checked the alcohol content of the gasoline ?
