2014 vw passat 2.0 tdi
- Autolatinopro
4 years 4 weeks ago #58244
by Autolatinopro
2014 vw passat 2.0 tdi was created by Autolatinopro
hey i have a problem. i just had my hpfp destroy my whole full system and i just finished replacing and flushing all of the fuel system (hpfp, in tank fuel pump and all four injectors rail pressure sensor and fuel rail solenoid reg) new injectors were calibrated to the ecu
i am now stuck with a fuel rail pressure to low code P0087 and i dont know what else can be happening. compression sound strong on my diesel engine, and i have replaced my whole fuel system what else could it be. on the scan tool fp is usually greater than 4500psi
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 4 weeks ago #58246
by juergen.scholl
Replied by juergen.scholl on topic 2014 vw passat 2.0 tdi
Make sure the hi pressure pump is timed correctly. Otherwise the pressure can be significantly lower than required without valve timing issues/other codes.
- Autolatinopro
4 years 3 weeks ago #58256
by Autolatinopro
Replied by Autolatinopro on topic 2014 vw passat 2.0 tdi
okay, i double checked for timing and when i line up all the marks to tdc the y pin that is behind the hpfp pully lines up perfectly to the hole where i need to put my special pin tool which hold the pully in place while i put the timing belt on.
what would i check for next?
thanks to everyone in advance:)
- Autolatinopro
4 years 3 weeks ago #58257
by Autolatinopro
also quick question i have a fuel pressure gauge hooked up before the hpfp and i get 62 psi max KOEO and when the fuel pump turns off the pressure drop to 0 psi in less than 5 seconds. is that suppost to happen?
- Garrym367
4 years 3 weeks ago #58284
by Garrym367
Replied by Garrym367 on topic 2014 vw passat 2.0 tdi
you hpfp reading should be higher than 62psi it should be into the thousands most fuel gauges would get blown off a hpfp. did you replace the injectors or get them sent away for repair. it could be partial blockage if the system wasnt free of shavings. it could also be one or more injectors returning to much fuel carry out a leak off test.
- Autolatinopro
4 years 3 weeks ago #58294
by Autolatinopro
the fuel pressure was measured before the hpfp, injectors are new and registered to the ecm. it only kicks into limp mode till i floor it which gives me a p0087 code, but if i am crusing slow im okay
watching data shows that when i floor it the rail pressure is almost 100000hpa behind the specific hpa required pressure, whcih is why it throughs p0087 and goes into limp mode
- juergen.scholl
4 years 3 weeks ago #58295
by juergen.scholl
What happens to the low side pressure when the high side pressure does not achieve the required value?
- Autolatinopro
4 years 3 weeks ago #58296
by Autolatinopro
the low side pressure stay between 60-62psi at all times.
- passdatvw
2 years 5 months ago #65437
by passdatvw
Replied by passdatvw on topic 2014 vw passat 2.0 tdi
I know its over a year old post, but did you ever find problem?
