2010 GMC Canyon (Chevy Colorado) 2.9 L3 p0017
  • GeekPriest
  • GeekPriest's Avatar Topic Author
4 years 1 month ago #58211 by GeekPriest
Troubleshooting a 2010 GMC Canyon with the 2.9 inline 4. P0017 code, incorrect cam/crank correlation. The cam solenoid tested bad and was replaced a few months ago, which reduced the problem.
Of note, the problem is INTERMITTENT, and the code will go away for 300-500 miles at a time. (This suggests I can rule out a stretched timing chain for now.)
Does anyone have a known good (I have a 2200 series Pico, so no access to their library) for the cam and crank WITH THE 3-Wire HALL EFFECT CRANK SENSOR? I've found some others but they all show a 2-wire sensor for the CKP.
Thanks for any tips or a known good.
4 years 1 month ago #58226 by Tyler
I've got a capture for the two wire CKP, but none for the three wire. :(
Do you have the Freeze Frame data for your P0017 when it resets? The conditions under which it resets may tell you something.
Before you go too much deeper into diagnostics, you might check for crankshaft end play. PIP3694F details the specifications:
static.nhtsa.gov/odi/tsbs/2015/MC-10139336-9999.pdf
The two Canyon/Colorado trucks I've seen with VVT problems were both out of specification according to the TSB, but still got fixed with phasers and chains. In other words, the crank end play needs to be WHOA and not 'meh' to be causing this fault, IMO.
Time to create page: 0.264 seconds
