Parasitic draw
  • Stevie15
  • Stevie15's Avatar Topic Author
4 years 1 month ago #58204 by Stevie15
Parasitic draw was created by Stevie15
Hello , I have a 2007 Honda odysseys with parasitic draw every 2 days the battery drain out I check all the fuses their all with in spec . I have noticed when ever I will open the driver side door the cluster light came on even with out the key in the ignition I had replace the cluster it does the same thing I don’t know what else to do any help will do thanks.
4 years 1 month ago #58283 by Garrym367
Replied by Garrym367 on topic Parasitic draw
hi stevie with you opening the door that isnt helping. you will be waking modules up and causing a drain. it didnt need a cluster that is common on cars to wake the cluster up as door is opened. discconnect the battery earth attach your multimeter to the earth post and earth lead of the battery set on amps. make sure all doors and windows are closed and the bonnet latch is closed over with a screwdriver. fool the car into shutting down. all are diffrent and can take an hour to turn off all modules. pull fuses for modules and see when the amp draw drops when it does find what stuff that fuse is supplying and test to see what is staying live
The following user(s) said Thank You: Stevie15
Time to create page: 0.266 seconds
