2013 Lexus IS250 P0139,P0159
  • Jalvrzjn
  • Jalvrzjn's Avatar Topic Author
4 years 1 month ago #58150 by Jalvrzjn
2013 Lexus IS250 P0139,P0159 was created by Jalvrzjn
I looked at a car today with the codes listed above. Slow response from both downstream oxygen sensors. I saw that the heater circuits were never controlled on for both banks. Immediately my Thoughts are if heater circuits are not operating properly then the sensors will not reach operating temp and not function as intended to. I tested the ground control for both sensors at the PCM with the vehicle running. Neither control wire for the sensors were grounding at all. I went ahead and added my own ground just to see what the sensors did and they started operating. I did check the ground for the PCM. At the PCM and it was below 200mv. I haven’t got to do any research on a software update yet. Just wanted to see if anyone has ran into this issue. The vehicle‘s rack and pinion was just replaced and on this vehicle, which involves dropping the engine and transmission assembly (I did not do the job). Any thoughts or insight would be greatly appreciated. Thank you
4 years 1 month ago #58153 by Noah
Replied by Noah on topic 2013 Lexus IS250 P0139,P0159
You'd think they would want to heat up fast, but I would check it driving. I feel like I remember hearing about a similar scenario in a case study or something...
  • Jalvrzjn
4 years 1 month ago #58154 by Jalvrzjn
Replied by Jalvrzjn on topic 2013 Lexus IS250 P0139,P0159
That’s a good thought. From my experience, The heater circuit is controlled on as soon as you start the vehicle. My thoughts were that both sensors going out at the exact same time is unusual also.
4 years 1 month ago - 4 years 1 month ago #58159 by Noah
I agree, almost every car I have looked at activates the heater circuit on start up or very shortly there after.
But I can't seem to shake the idea that I've read about, heard about or saw a video about downstream heaters not coming on at start up/idle.
Last edit: 4 years 1 month ago by Noah.
  • Jalvrzjn
4 years 1 month ago #58162 by Jalvrzjn
Thank you for your insight
4 years 1 month ago #58197 by Noah
Just wondering if you found anything interesting. No pressure.
  • Jalvrzjn
4 years 1 month ago #58198 by Jalvrzjn
Not yet. I have to go back to the vehicle and do some more checks. I will definitely keep you updated
  • Jalvrzjn
4 years 1 month ago #58255 by Jalvrzjn
OK so I figured it out and I feel like a dumb ass. Instead of going after the O2 sensors I read the codes on all data. If I remember right it stated that the code is caused by a slow response after fuel cut off. I checked my fuel trims while driving and I noticed that during acceleration my fuel trims would go lean. During a hard acceleration I could get them to go rich with plenty of power. I did not suspect A fuel pump problem. Also during the test drive I noticed that the heater circuits work properly. You were right. So initially I went straight for the mass airflow sensor and found that the intake tube was improperly installed allowing unmetered air. Fixed. Thanks again
Time to create page: 0.358 seconds
