2003 dodge neon sxt 2.0 stalls
  • Jaguarpaw
  • Jaguarpaw's Avatar Topic Author
4 years 1 month ago #58138 by Jaguarpaw
2003 dodge neon sxt 2.0 stalls was created by Jaguarpaw
I have a 2003 dodge neon sxt 2.0 vin C 8th digit.
Bought it cheap thought I could figure it out easy but it’s been a pain. Car will start right away and idle fine. Once you put it in drive and start driving it will stall. I get both cam and crank sensor intermittent codes. I checked the wiring, the pcm has been replaced, both cam and crank sensors have been replaced, timing belt has been replaced, the cam magnet behind the cam sensor has been replaced. It has a crack but made no difference after replacing it. The connectors to the pcm and cam sensor have been replaced. I never felt so lost. I got some wave forms from the crank and cam sensors using a scanner to see if I can check if timing was off but I’m new to using it and are not sure what I’m lining up
Attachment not found
4 years 1 month ago #58169 by Cheryl
Replied by Cheryl on topic 2003 dodge neon sxt 2.0 stalls
You might be losing the hole 5 volt reference. Might want to check if your losing it then go from there
  • Jaguarpaw
3 years 11 months ago #58700 by Jaguarpaw
Replied by Jaguarpaw on topic 2003 dodge neon sxt 2.0 stalls
The car only dies when I put it in gear and start to accelerate. It never dies at idle in park even if I rev the engine. The cam and crank sensors are both after market would that effect it?
