Toyota Prado code 12
  • Mattar
  • Mattar's Avatar Topic Author
4 years 1 month ago #57852 by Mattar
Toyota Prado code 12 was created by Mattar
Hello, I hope everything is going well? I have a 1998 Toyota Prado it is the 90 series and the model of it is the rzj95r. The type of engine it has is the 3rz-fe 2.7 litre 4 cylinder engine. The Prado is manual and a four wheel drive. I have pulled a fault code 12. The symptoms of what the car is doing is this, when the car is cold I start the car and in about 10 seconds or less the car would stop but if I start the car and press on the accelerator and keep it there for about 30 seconds to 1 min then left my foot off the accelerator it will stay running. I did notice that the tachometer does not move at all and that the check engine light stays on. I am starting with the crankshaft positioning sensor, I do not know if that is where I should start. With this sensor I do not know if it is a hall effect or a inductive sensor in the repair manual it does not say. On the sensor it self it has 3 wires that connects to a 3 male pin connector there is 2 wires that actually connects to the sensor itself and to the male connector the 3rd wire connects to the male connector but does not connect to the sensor. I believe this wire might a shield wire but I am not sure.
  • Mattar
4 years 1 month ago #57853 by Mattar
Replied by Mattar on topic Toyota Prado code 12
I also live in Australia
4 years 1 month ago #57855 by mashili
Replied by mashili on topic Toyota Prado code 12
Does it have a distributor or pick up coils
  • Mattar
4 years 1 month ago #57857 by Mattar
It has a distributor
  • Mattar
4 years 1 month ago #57858 by Mattar
Yes it has a distributor
4 years 1 month ago #57875 by mashili
Code 12 for Toyota is a faulty distributor
  • Mattar
4 years 1 month ago #57876 by Mattar
So it would then have nothing to do with the crankshaft position sensor? And another question is the crankshaft position sensor that is in that car a hall effect or a inductive type sensor?
  • Mattar
4 years 1 month ago #57891 by Mattar
Here is a picture of the distributor rotor, would this cause the fault
Time to create page: 0.370 seconds
