erratic vibration at idol
- RickD.
- Thank you received: 1138
Is the vibration worse in gear than it is in park?
I'm thinking of the possibility of junk engine mounts considering there was no dtc stored. If you can lift the engine with a large bar and the vibration gets better, suspect an engine mount.
You can absolutely use the Solus Pro to check data pids to help point you In the right direction, even if there are no trouble codes!
If you haven't already, you might want to consider signing up for the free trial of Scanner Danner Premium where you'll find hands down, the best instructional series on the use of your Solus Pro.
Solus Pro Training: www.youtube.com/playlist?list=PLM4TD8VJ3...BPSJiW2yINRfsZxGv1KL
The other things to look at are the idle speed control valve and egr valve and also cleaning the throttlebody.
- RickD.
- RickD.
RickD. wrote: I bought a toyota corolla ce with a 1.8 engine around 3 weeks ago and it also vibrates at idol. I connected the solus pro to it and reviewed the Pid's. The Pid's are as follows: RPM - 748, ST FT 2.3 - 3, LT FT 5.4, IGN ADV 17.0 - 18.0, MAF (g/s) 1.84, Throttle Pos 16-17 and Inj (ms) 2.3. I don't know what the normal Pid readings should be so can anyone tell me if any of these Pids can be the cause for a rough idol. No DTC found. Thanks in advance.
Sorry, I'm confused now :blush:
Are these data pid values for the Neon or another Corolla? I don't see any smoking gun there...
I'm also still kind of unclear about the exact symptom. You called it "an erratic engine vibration at idle".
The vibration part is what got me thinking motor mounts. When you say erratic, is the rpm changing drastically? Or is this like more of a rough running, misfiring condition?
Sorry if I seem like I'm nit-picking, it's just kind of hard to get a sense for what the car is doing from where I'm sitting;)
I like Andy's vacuum leak testing suggestion. I'm pretty sure the Neons of that vintage had the throttle body on the air box and not on the intake. Since you were just in there changing the big air breather tube, it may be worth a second look see to make sure all the clamps are nice and tight, any small tubes or lines are all securely fastened and that the air cleaner box itself is sealed nice and proper.
Any air leaks in any of these areas will not be accounted for by the MAF, and cause rough running or stalling.
- RickD.
