Short on coolant sensor wire going into cluster
  • twinscrew9.0.twinscrew9.0
  • twinscrew9.0.twinscrew9.0's Avatar Topic Author
4 years 1 month ago #57805 by twinscrew9.0.twinscrew9.0
Short on coolant sensor wire going into cluster was created by twinscrew9.0.twinscrew9.0
I have a 1999 Ford f350 V10 I have a coolant sensor wire cut right before it goes into cluster it has 11 volts on it when I unplug the cluster it goes away tried new cluster same thing this short is causing my pcm to pop the coolant sensor circuit in pcm when I put new pcm in any ideas thanks
