Nissan Murano Z51 QR25DE (P0335,P0605)
4 years 2 months ago #57790 by Saed
Hi all,
My friend has a Nissan Murano Z51 QR25DE it has been sitting for about a year now, on average it starts once every 10 times of cranking.
Trouble codes: P0335 CKP sensor circuit, P0605 Internal Control Module ROM Error.
-Both Cam and Crank sensors have been replaced with new aftermarket sensors.
-ECU has been replaced with a working second hand one.
-Wiring visually checked from ECU to the cam & crank sensors, continuity test okay.
-5 Volts reference is present KOEO
How it all started.
The car had a seized AC compressor last year and the owner tried to crank it a few times but the engine wouldn't crank, after replacing the AC compressor, car started and the problem started. after replacing both cam and crank sensors, the ECU was replaced but not programmed, it still had the same symptoms and same code still starts once in a while.
I've checked the cam and crank wave form and something looks really odd (photos attached), I'm no expert when it comes to scopes but there seems to be a lot of spikes when the starter operates and for some reason the pattern is not even, also the supply goes up to 9 volts sometimes.
I have no clue of what to check next, I also couldn't find a wiring diagram for the Z51 2.5L :(
If anyone has any sort of advice of where to go from here, please post your ideas. Thanks
4 years 1 month ago #57982 by Rallymechanic
Replied by Rallymechanic on topic Nissan Murano Z51 QR25DE (P0335,P0605)
a quick thought, would be check the engine earths.
4 years 1 month ago #57984 by Noah
Replied by Noah on topic Nissan Murano Z51 QR25DE (P0335,P0605)
What is the year?
4 years 1 month ago #57994 by Saed
Replied by Saed on topic Nissan Murano Z51 QR25DE (P0335,P0605)
Hi, it's a 2009
4 years 1 month ago #57995 by Saed
Thanks for your response. will check the grounds with a light bulb to make sure they're good enough
