Could use some help understanding my scope waveform
- K1000
4 years 2 months ago #57630
by K1000
Could use some help understanding my scope waveform was created by K1000
2006 CHEVROLET SILVERADO 2500HD 6.0l gas LQ4. No DTCs stored. I graphed the throttle position sensors (1&2) because I have been having random stalling issues on this truck.
**WITHOUT THE FAULT OCCURING**
Throttle position sensor 1 drops to zero , throttle position sensor 2 does not. Throttle position sensor #1 5v ref drops to zero. Throttle position sensor #2 5v ref does not.
In my scope:
green: tps1
yellow: tps2
red: tps1 5v ref.
blue: tps2 5v ref.
Specifically, how do I know if the position sensor is bad or if the TAC module (mounted on the firewall of this truck) is faulty. I suspect the position sensor is shorting the 5v ref. down.
Also, why does it not set a code? I suspect it does not set a code due to happening 5 times per second and the condition for setting a code is shorted to ground for 1 sec.
I played around with this and if I unplug the throttle body connector, all the wires read a constant 5v (which really confused me because I did not expect that). Following the diag chart for P0120, it appears the signal should have 5v when unplugged.
Any thoughts on this would be helpful, thanks.
In my scope:
green: tps1
yellow: tps2
red: tps1 5v ref.
blue: tps2 5v ref.
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 2 months ago #57633
by juergen.scholl
Replied by juergen.scholl on topic Could use some help understanding my scope waveform
You may want to disconnect the 5V reference #1 terminal within the throttle body connector. Then jumper the 5 V #2 reference to this terminal. A shorted tps 1 would then pull down the ref 2 voltage.
With the connector unplugged you really get 5V on ALL wires, even the low reference/ground ones? If this is not the case and the 5V are present on the signal and reference wires only than it probably is a pull down sensor design.
- K1000
4 years 2 months ago - 4 years 2 months ago #57635
by K1000
Replied by K1000 on topic Could use some help understanding my scope waveform
I only have 5v @ both signal wires and both 5v reference wires with the connector unplugged. Low reference is 0 volts. Checked w/scope, no meter.
Ok. This is what I have done. I started over because I realized I was mistaken and tps2 is the problem, not tps1.
My trace colors are:
Yellow - position E on the connector - only labeled 5v, I assume for tps#2
Green - position F on the connector - tps#2
Blue - position G on the connector - tps#1
Red - position H on the connector - only labeled 5v, I assume for tps#1
First, I depinned terminal H and E and swapped the terminal positions (H&E are both 5v references for the throttle body). Doing this set a code and the reduced power message on the dash(could not clear, dead fault). I reswapped the terminals back to their original positions. No codes. Then I verified my results by doing it again. Same thing, set a code and reduced power message. With the throttle blade in default, my scope was fine, no dropping out 5v good, tps sensors both matched.
Second, I depinned and swapped H&E, F&G all at the same time. When I did this, the problem followed the wires/terminals. Thus, the red trace and blue trace showed the dropping out.
Third, I put all the terminals back to their proper position from factory. When I did this the problem followed the wires/terminals. The yellow and green traces showed the dropping out.
After the problem followed the wires, I scoped the low reference wires @ the throttle blade. They seemed fine/stayed @ 0v. Then I scoped the throttle blade motor terminals and it appears motor control 1 drops to zero as well. Motor control 2 stays constant @ 12v.
I retested with the throttle body unplugged. Motor control 1&2 show 5v, tps1&2 5v references show 5v. I reconnected but with the reduced power message, same thing. 5volts for all 4 wires mentioned. Once I cleared the code, then it was back to motor control 1 drops out like tps2 5v reference.
So, a module related issue or still a throttle body issue? Motor shorting out internally?
Earlier, I scoped the TAC module power and ground. If the module was unbolted from the firewall, it acted like no ground(12v) but with I bolted it to the firewall it has a good ground. Looking back, maybe I had a bad connection on the ground terminal for TAC module ground. Thus, I just rescoped power and ground to the TAC module. I even captured the truck stalling but unfortunately, my terminal probe was no good on the tac module power. I have to try to catch it happen again. When it did start and stall, it appeared the ground was good. Picture included. (blue= tac ground/ red-tac power(assumed bad connection)).
Side note, it has started and stalled twice today; both times it was when I unbolted the TAC module from the firewall. That said, I have tapped on the module (no change) and I left it unbolted and now the truck works fine again.
**edit**: Unless motor control 1 should be constant @ zero and the fact that it is 12v indicates a bad module ground and/or module?
Last edit: 4 years 2 months ago by K1000. Reason: see edit @ bottom of post
