Hi, I have a no crank no start on a 08 Trailblazer. It will start jumping at the relay (87 to 30) but then shuts back off with the key on in run. But I found that the pink wire(Coming from the ignition switch) has constant voltage to it, low voltage but then when I crank the vehicle it gets very bright (PINK WIRE) but it never sends power or ground to 85 to start and the instrument cluster stays on like you left the key on then have I have to disconnect battery then its fine until you try to crank it again or just turn the key on. Thanks
Last edit: 4 years 2 months ago by Primetimeups. Reason: Forgot specific area I'm referring to.
Step 1 is to do a full system scan on all modules. If the cluster is staying lit up with they key off, you'd think you'd have some trouble codes to give you direction
What does the security light do, when you try to start?
"Understanding a question is half an answer." I have learned more by being wrong, than I have by being right.
