2011 Jeep Liberty kk VIN Mismatch
- Mohsen
4 years 2 months ago #57478
by Mohsen
1. Speedometer stops working. 2. The fuel gauge drops. 3. AC stops working. was created by Mohsen
Hi,
I hope you and your family are well.
I need your help.
I have a problem in 2011 Jeep Liberty kk 3.7.
I have seen several vehicles with same problem.
When replacing the PCM and writing the vehicle's VIN in the new PCM, the next happen:
4. ABS and stability control indicators come on.
When connecting the scan tool and reading the trouble code from the ABS, the code is C2206 Vehicle configuration mismatch.
Although the same right VIN is programmed in the PCM and the ABS.
I appreciate your help.
I need your help.
- Mohsen
4 years 2 months ago #57507
by Mohsen
Replied by Mohsen on topic 2011 Jeep Liberty kk VIN Mismatch
Hi,
I need your help.
4. ABS and stability control indicators turn on.
I need your help.
4 years 2 months ago - 4 years 2 months ago #57508
Replied by Chad on topic 2011 Jeep Liberty kk VIN Mismatch
C/P
NOTE: This DTC will be active when a new module is installed until initialization is performed.
1. Turn the ignition on.
2. With the scan tool, read and record the DTCs.
3. With the scan tool, read and record Freeze Frame information.
4. With the scan tool, erase the DTCs.
5. Perform ECU initialization on ABM. Refer to ABS VERIFICATION TEST See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > ABS Verification Test.
6. Cycle the ignition switch from off to on.
7. With the scan tool, read and record the DTCs.
Have you performed, or do you have a scan tool capable of performing the ABS module initialization?
Last edit: 4 years 2 months ago by Chad.
- ScannerDanner
- Administrator
- Thank you received: 500
4 years 2 months ago #57515
by ScannerDanner
Don't be a parts changer!
Replied by ScannerDanner on topic 1. Speedometer stops working. 2. The fuel gauge drops. 3. AC stops working.
I have no suggestions for you my friend. Hoping someone else can jump in here for us. Thanks for using my forum!
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 2 months ago - 4 years 2 months ago #57517
by juergen.scholl
Replied by juergen.scholl on topic 1. Speedometer stops working. 2. The fuel gauge drops. 3. AC stops working.
Have a look at Chad's reply in the other thread....
www.scannerdanner.com/forum/post-your-re...kk-vin-mismatch.html
Initialize the ABS module.
Last edit: 4 years 2 months ago by juergen.scholl.
- ScannerDanner
- Administrator
4 years 2 months ago #57520
by ScannerDanner
So there was another thread already on this?
- juergen.scholl
4 years 2 months ago #57521
by juergen.scholl
Looks pretty much alike, same user, same car, same problem etc??
- ScannerDanner
- Administrator
4 years 2 months ago #57522
by ScannerDanner
@Mohsen
There was already a thread on this? If so, why did you create another one?
4 years 2 months ago - 4 years 2 months ago #57526
Replied by Chad on topic 1. Speedometer stops working. 2. The fuel gauge drops. 3. AC stops working.
I will have merged the two threads.
- Mohsen
4 years 2 months ago #57564
by Mohsen
Thank you and to all of you guys who replied.
I have a scan tool Launch x431 pro 3.
I performed ABS initialization but it fails.
Note: although that the initialization fails, the VIN is identical in both ECU and ABS modules.
Sorry for making 2 threads with the same problem, it my mistake.
- juergen.scholl
4 years 2 months ago #57597
by juergen.scholl
Replied by juergen.scholl on topic 2011 Jeep Liberty kk VIN Mismatch
Is there any reason given why the initialization fails? Can you execute the procedure with a different scanner as sometimes they won´t do what thet promise...
Time to create page: 0.370 seconds
