2015 chevy truck Electronic brake control module
  • warren.kruger
  • warren.kruger's Avatar Topic Author
4 years 2 months ago #57433 by warren.kruger
got a 2015 chevy truck with traction control, ABS, brake lights on dash also limited power steering info in human device interface message...scan the truck with scan tool...could not communicate with electronic brake control module ..all other systems say no communication with brake control module.so went and checked powers and grounds with brake control module all good......so is this a bad module ?....
4 years 2 months ago #57435 by Dtnel
Check service information for tsb’s as you could have a part that’s a known issue.
Check the vehicle service information, go thru tests per service information as it may have other suggestions as well may have you try to reflash it. Dealing with something similar on a BCM on a 06 Hummer H3 myself.
4 years 2 months ago #57437 by Cheryl
You have to check the gm high speed data lines coming in and coming out of abs module. Use a headlight to load test powers and grounds. Check terminals on connector
