2000 F150 Gauges
  • festus
  • festus's Avatar Topic Author
9 years 6 months ago - 9 years 6 months ago #8749 by festus
2000 F150 Gauges was created by festus
I have a 2000 f150, 4.2 v6 automatic rear wheel drive. This truck has no engine related codes, the abs light is on, haven't pulled that code yet. It has a little bit of a weird instrument cluster thing going on. If you go to start it like a normal vehicle it will turn over but not crank. When you let off of the key the gauges will sweep all of the way to their max, pause then go back to normal. Then it will start no problem. If you turn the key on and wait for the gauges to sweep it will start with no problem. But if you do not wait then it will turn over but not crank. Once started it runs perfectly. By coincidence I happen to have another f150 same year and same motor different transmission, that does not have this gauge sweep problem. I am at a loss for what could be the cause or where to even start. Does anyone have a clue?
Last edit: 9 years 6 months ago by festus.
  • GeekDIYMechanic
  • GeekDIYMechanic's Avatar
9 years 5 months ago #8795 by GeekDIYMechanic
Replied by GeekDIYMechanic on topic 2000 F150 Gauges
Were there any modifications to the truck, e.g. alarm system, remote start, ....? Is it completely stock?
  • festus
9 years 5 months ago #8798 by festus
Replied by festus on topic 2000 F150 Gauges
As far as i know and can tell there are no mods at all, completely stock
9 years 5 months ago #8804 by Doc n2mx
Replied by Doc n2mx on topic 2000 F150 Gauges
Hi..
My first check would be the ignition switch. I would test the switch and the wires in the column.
Test to see if the switch is indeed working each circuit. Also check your relays.
Good luck
Doc n2mx
