2007 mazda 3 intermittent no start
  • mudman
  • mudman's Avatar Topic Author
4 years 3 months ago #57013 by mudman
2007 mazda 3 intermittent no start was created by mudman
I have a 2007 mazda 3 2.0 auto the relay intermittently does not always engage to let power to starter . I load tested battery which is fully charged then I tested voltage at relay and get 12.4 volts on both the battery terminal and the ignition terminal. Could I be losing ground to keep the relay from sending power to the starter. fyi starter works fine if you jump power to solenoid terminal and car will start most of time with the key
4 years 3 months ago #57020 by Noah
Replied by Noah on topic 2007 mazda 3 intermittent no start
I think a good place to look without getting too intrusive is scan data.
Check for ignition switch position, park/neutral, start request and starter relay command.
If the request is seen and the command is not sent, then it's time to look toward inputs. If the command is sent and the starter doesn't operate, then it's time to do some circuit checks.
  • mudman
4 years 3 months ago #57023 by mudman
Replied by mudman on topic 2007 mazda 3 intermittent no start
the command is being sent to the relay but the relay doesn't always transfer power to starter
