2008 focus 2.0 standard shift
  • Cheryl
  • Cheryl's Avatar Topic Author
4 years 3 months ago #56932 by Cheryl
2008 focus 2.0 standard shift was created by Cheryl
The owner keeps getting a p2135 has replaced throttle body 2 times. And app sensor once. The app is a used one he said the first throttle body was used 2nd a standard Brand. I found a corroded wire at the throttle body fixed it now it goes into reduced power intermittently. Before I found it it was a hard fault. Can a glitching app sensor cause a throttle body code? I have a screenshot of the glitch I caught.
  • Cheryl
4 years 3 months ago #56933 by Cheryl
Replied by Cheryl on topic 2008 focus 2.0 standard shift
If you look up the code on Mitchell it doesn’t say anything about the app being a possibility but I’m thinking that’s the issue but figured I’d ask
  • Cheryl
4 years 3 months ago #56947 by Cheryl
It’s been to 3 shops used pcm used throttle body used app. It was a hard fault when I first got it. Start it up it’d go into reduced power now it’s intermittent. Put original app back on been driving it all day so hopefully it’s fixed I’ll drive it til Saturday before I call if a fix
4 years 3 months ago #56950 by Noah
Replied by Noah on topic 2008 focus 2.0 standard shift
I got dragged over the coals on a Buick over app/top codes a few weeks back. The APP had failed and I correctly identified the problem, but the brand new APP didn't play nice and kept setting the same codes. 3 brand new pedals to be exact...
I finally went to the junkyard for a GM one, problem solved.
  • Cheryl
4 years 3 months ago #56953 by Cheryl
It was the used oem ford pedal from the junkyard. Must of been sitting outside in the weather and what not been fine for 2 days now fingers crossed
  • Cheryl
4 years 3 months ago #57011 by Cheryl
Well just acted up today
4 years 3 months ago #57015 by Noah
Balls....
  • Cheryl
4 years 3 months ago #57047 by Cheryl
Would you have a spec on w.o.t. App and tps readings? Along with closed throttle
  • Cheryl
4 years 3 months ago #57053 by Cheryl
At this point I’m leaning towards pcm. I’m scoped at the pcm and found a table that shows the tps voltage specs open and closed throttle. Forgot the exact numbers. Have no drop outs and was in spec. Seems worse if you let it hot soak for a half hr or so
  • Cheryl
4 years 3 months ago #57072 by Cheryl
Checked terminal drag at pcm connector. And scope patter looks good when wrench light comes on and throws it in reduced power
  • Cheryl
4 years 3 months ago #57136 by Cheryl
Installed used pcm owner drive it 175 miles already on a trip didn’t go into reduced power once
Time to create page: 0.345 seconds
