1993 ford mustang foxbody 5.0L v8 dealing with a no start
  • Autolatinopro
  • Autolatinopro's Avatar Topic Author
4 years 3 months ago #56912 by Autolatinopro
hey guys i am working on a 1993 ford mustang foxbody 5.0L v8 dealing with a no start.
spark is good but no injection control to all injectors(confirmed with noid light test and i scoped the control wire & no signal)
we sprayed a lot of starter fluid and it almost started but then nothing. after that i confirmed 45 psi on fuel pressure which is good
i scoped the pip sensor for cranking becuase it doesnt start
is the pip or TFI module cause a spark but no injector pulse problem?
i also check the power and grounds at the ecm and they seem good
all the injectors have a good constant 12v on the red wire and 12 volts constant on the signal wire. indicating a bad ground or trigger sensor problem
any ideas would be awsome thanks
Time to create page: 0.260 seconds
