Treated myself. Oxy-MAP
5 years 4 months ago - 5 years 3 months ago #49817
Treated myself. Oxy-MAP was created by Andy.MacFadyen
I have been without access oxy-acetylene for too long and somethings a MIG isn't suitable so I bought an Oxy-Map gas mini porta pak. Useful but only a make-do substitute for the real thing.
Only used it for brazing so far but it was okay.
Last edit: 5 years 3 months ago by Andy.MacFadyen.
- Matt T
- Thank you received: 276
5 years 4 months ago #49822
by Matt T
Replied by Matt T on topic Treated myself. Oxy-MAP
Best you can do over there without a bunch of BS and expense.
I mostly run oxy propane. Cheaper to run and way higher cutting and heating capacity on the portable rig. I only use acetylene for welding.
5 years 3 months ago #49845
Replied by Noah on topic Treated myself. Oxy-MAP
Will it cut?
5 years 3 months ago #49858
Replied by Andy.MacFadyen on topic Treated myself. Oxy-MAP
No cutting, really small cylinders with welding nozzles.
For cutting these days I would want a plasma cutter but that needs a decent compressor.
5 years 3 months ago #49860
I'm useless without Oxy/Acetylene but then again i see a good deal of rust. I like to blast sway bar links off with the torch without even trying to get them with the gun.
I used to pull radiators and rear ends with nothing but the cutting torch at the junk yard. Very important tool!
That looks like a nice little rig for heat to keep from breaking things though.
- AJeep18
- Thank you received: 34
5 years 3 months ago #49863
by AJeep18
Replied by AJeep18 on topic Treated myself. Oxy-MAP
5 years 3 months ago #49864
Yup, cut the spring clamp and the hose gets nice and mushy, lol
Time to create page: 0.382 seconds
