02 sensor rethread
  • Charlie 89
  • Charlie 89's Avatar Topic Author
5 years 7 months ago #47414 by Charlie 89
02 sensor rethread was created by Charlie 89
Has anyone used the Helicoil 4833 Oxygen Sensor Thread Repair Kit ?? Wanting to know if it's difficult to use haven't found any videos on youtube
5 years 7 months ago #47419 by Nelson60
Replied by Nelson60 on topic 02 sensor rethread
Havent used it but wonder if just O2 sensor thread chaser is good enough to clean up threads to use?
5 years 7 months ago #47422 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 02 sensor rethread
Normal O2 sensors are the old M18x1.5 spark plug thread --- last used on Ford SOHC
Normally a chean up with a thread repair chaser tap is all that is required.
The thread on sensor boss is quite short so using a Helicoil might be tricky but timesert style solid insert kit,
  • Charlie 89
5 years 7 months ago #47424 by Charlie 89
Replied by Charlie 89 on topic 02 sensor rethread
Unfortunately 02 sensor came out really damaged I did use a thread chaser but 02 sensor will not grab it just spin's
5 years 7 months ago #47427 by AJeep18
Replied by AJeep18 on topic 02 sensor rethread
If it were me and I wanted to do it on the cheap (and if you have a welder of course). I would just fill weld a plug in the old hole and weld a new bung on in roughly the same spot, or you could even cut the bung off and weld a new one where it used to be.
Something like this depending on your thread size.
www.amazon.com/Ledaut-Mounting-Notched-F...id=1615642846&sr=8-3
  • Charlie 89
5 years 7 months ago #47433 by Charlie 89
Unfortunately I don't have a welder or know anyone around the area that would do that
