How do I hookup my scope?
- Jace
6 years 5 months ago #40329
by Jace
How do I hookup my scope? was created by Jace
I have an Autel scope on its way and I would like to know how to properly hook it up. Does every channel lead have to be grounded or just one channel needs to be grounded?
- juergen.scholl
- Active partschanger
- Thank you received: 462
6 years 5 months ago #40334
by juergen.scholl
Replied by juergen.scholl on topic How do I hookup my scope?
The 4 channels do share a common ground. If one channel's ground lead is connected to chassis ground all 4 channels are at the same potential. There is a dedicated led showing what the manual calls "equipotential".
- Jace
6 years 5 months ago #40347
by Jace
Replied by Jace on topic How do I hookup my scope?
thank you. Is there anything wrong or harmful to the scope of I connect more than one ground?
- juergen.scholl
6 years 5 months ago #40348
by juergen.scholl
No, but all ground leads must be connected to the same potential, in your case chassis ground/negative battery post.
Jace wrote: Is there anything wrong or harmful to the scope of I connect more than one ground?
6 years 5 months ago #40438
Replied by Andy.MacFadyen on topic How do I hookup my scope?
The way you route both the signal and ground cables to the scope can have a big effect on how clean and hash free the scope trace is. Both signal and ground should be routed as far as possible away from any unit on the car such as coils, alternator, injectors or fan motors that could cause electromagnetic interference. That is why you will see in a lot of videos the leads hooked up on to the hood up clear of the engine
- Landroverman1958
- Thank you received: 17
6 years 5 months ago #40441
by Landroverman1958
Replied by Landroverman1958 on topic How do I hookup my scope?
I would also say to get a sensor clean signal,use the sensor ground as it will be cleaner and have less noise on it,the signal(s) will be cleaner.if of course the sensor has a separate ground,ie on a hall effect.
- juergen.scholl
6 years 5 months ago #40442
by juergen.scholl
Although this is a good recommendation for a single channel capture the OP, as relatively new to this topic, has to be made aware of possible ground loops and resulting problems while capturing more than just one channel at a time.....
