Have you ever measured resistance on an airbag with DVOM
- Dylan
- Belgium, Europe
- Thank you received: 327
- Thank you received: 1552
I did put a scope on a pretensioner circuit before! Got a lot of flak from others for that, too. :silly: Oh well.
Speaking of the ohm meter, has anyone measured how much current one generates? :huh: I feel like Paul may have at one point...
- ScannerDanner
- Administrator
- Thank you received: 500
On a separate note. I've recently learned the hard way to NEVER rotate an airbag module with the key on. Smh
The rollover sensors are in the module and it blew the side curtain bags. Yes, I have it on video too
Don't be a parts changer!
- Dylan
- Belgium, Europe
I'd love to see the video Paul
- Dylan
- Belgium, Europe
Tyler wrote: Never. Always wanted to.
I'd also like to know how much current the ohm meter generates. I think Paul has mentioned in one of his videos it's in the milliamp range.
- Thank you received: 1142
I didn't know about the module thing though! I'll be cautious when it comes to those from now on.
The plug connector on an airbag has a shorting bar so if you try and measure the resistance unless the the shorting bar is lifted clear or put out of action the airbag or pre-tensioner squib with read a dead short. Substituting 2 ohm resistor is still probably the easiest test.
My experience sugests where there hasn't been a crash impact 95% of air bag faults are due to bad contacts in connectors, 4% are down to water ingress into the impact sensors.
The other question is how much curent is needed to set off an airbag squib
- JeffBirt
- Thank you received: 34
Then, what is the cost of the failure you might cause vs. the value of the time saved? There was one piece of equipment I worked on where you needed to clean an optical sensor when doing a service. Getting to the sensor by the book took 20-30 minutes. But, you could bend a metal flap slightly, pull it out and have access to the sensor; which took about 20-30 seconds. If you slipped you could damage a $200 part though. Given the time saved doing several of these jobs a week it was worth the risk but if it was a potentially very expensive part (like airbags) it would not have been worth it (IMHO).
From what I think reliable sources the amperage used for firing off a single air bag pyrotechnic is 1 to 3 amps ---- which implies they should fire reliably at as low as 2 volts.
Measuring my varied collection of meters testing the open circuit voltage accross the test leads on the ohms scales none showed more than 300mv open circuit voltage.
Putting 3 ohm load on and the voltage accross the load dropped below anything I could measure with any of my meters and current was measured in all cases at less than 0.3ma
So know your DMM and make your own judgement at your own risk --- I would not advise using a Power probe or old style analogue meter (aka an "AVO" meter) Having said all that airbag pyrotechics are dangerous and substituting a 2 ohm ressistor is still the weapon of choice.
- Dylan
- Belgium, Europe
Totally agree here. I do NOT encourage anyone to measure resistance on an airbag. Even if the chance is pretty small for the airbag to deploy and there's a shorting bar to bypass don't risk it. A loose airbag unit that explodes is lethal.
We used to set off airbags at the Toyota dealership after replacing them because of some TSB. Can't remember what the issue was. But man the first time I did that I'll never forget. I squeezed it very tight in the vice, took some wires and a battery. The thing wouldn't even go off just by putting battery voltage to it. So I started pulling some sparks at the battery and that was the loudest bang I've ever heard. Boss ran into the shop. Poor guy thought his garage was gone. I'm laughing now but I wasn't at the time :lol: Should've taken it outside and blow it on the roof.
I know it was at least 30 feet because it landed on top of the car stripping tent and bent one of the supports...
- scopeman
- juergen.scholl
- Active partschanger
- Thank you received: 462
So the resistance box is suitable for checking out the air bag circuit.
- scopeman
- George Uk
- Thank you received: 6
I see know need to, to be honest. Substitute the bag in question with a resistor of equal value and if your code goes away, the wiring and computer are fine.
WOW !!
Never knew or thought that could happen, for sure never mentioned in the BOSCH (UK) Airbag Training course. In their (Bosch) defence they do teach you to handle Airbags with Ign OFF & Battery Disconnected and allow time for Caps to discharge.
Im so glad I read this - Lesson Learnt, Disaster Averted !!
