Caliper cleaning tool?
- Tutti57
- Thank you received: 254
7 years 11 months ago #24606
by Tutti57
Caliper cleaning tool? was created by Tutti57
Which method do you do when servicing/repairing brakes to clean the caliper brackets under the hardware.
I've tried a few different ways but am not sure which one I like the best. I have used a 90* die grinder with a green cookie, straight 3" cut off wheel, and Sawsall.
What do you you to use?
7 years 11 months ago - 7 years 11 months ago #24610
Replied by Andy.MacFadyen on topic Caliper cleaning tool?
For normal servicing chip the worst off then an angle grinder with wire brush. - wear eye protection and face mask, then flap wheel. I have two angle grinders one always has a wire brush in it the other setup for a flap wheel or grinding disk.
Never tried one of those pneumatic needle chippers but I have seen them used for big stuff.
I noticed Eric O has some good tools for this kind of work.
For anybody restoring a car that can soak the parts for a month or so in hand there are other ways that will bring the steel parts up like new --- mild acid bath (vinegar or citric acid or phosphoric acid) or even better electrolysis in a soda solution.
Last edit: 7 years 11 months ago by Andy.MacFadyen.
- Matts Auto
- Thank you received: 28
7 years 11 months ago #24619
by Matts Auto
Replied by Matts Auto on topic Caliper cleaning tool?
I use a pneumatic needle scaler works great & doesn't take off excess material from the bracket. Snap on sells bluepoint version for under a $100
The following user(s) said Thank You: Andy.MacFadyen, Tutti57
7 years 11 months ago #24624
Replied by Noah on topic Caliper cleaning tool?
I like the needle scaler tool, but have never used it for this purpose.
I usually knock off any big rust scales, then follow up with a brown cookie wheel on the die grinder then give it a once over with a triangle shaped file that I can get into the corners and crevices.
- Tutti57
7 years 11 months ago #24679
by Tutti57
Replied by Tutti57 on topic Re:Caliper cleaning tool?
Yeah, I saw Eric o using a media blaster that worked awesome. I will investigate the needle scale scaler method. Thanks for sharing!
