How can a person get better at reading wiring diagrams
- Jay2034
- ScannerDanner
- Administrator
- Thank you received: 500
Jay2034 wrote: Hey what's going on Paul. Usually I always email u but thank u for taking ur time for the PM. But what's a PM? And how do I check it. Lol. I'm so serious
I'm so sorry Jay2034 that was meant for pole71
A PM is a private message and you'll find them under your profile image
Don't be a parts changer!
Jay2034 wrote: Thank u once again guys. So what bout the fuse 7.5 that inside the box that only has power on one pin and the other has 1.2 volts. How can I attack that.
This is without the fuse inserted, correct? Put a fuse in it. Set a multi-meter to Milli-volts DC (MV). Using the two test points of the fuse, Measure the voltage drop across the fuse. Is there one?
- Jay2034
I believe, this is the power source for some sort of communication between the window motors and the GCMU. I could be wrong about that, too.
What I am sure of is that, if there is current flow through that fuse, you will see a voltage drop. That is my concern, right now.
You can operate the windows and watch the amperage.
- Jay2034
Because with the fuse in and I touched the pins there were 0 volts on each pins with it in
Do you have the negative test lead touching a ground? (you should read 12v on both test points) Or, are you measuring like this:
If you are reading 0 volts, measuring like the picture, this means you have 0 voltage drop...no current flow.
If you are measuring like the picture and get a reading, other than zero, this is a voltage drop across the fuse. This indicates current flow. Compare this reading to the chart.
- Jay2034
Jay2034 wrote: if I do have current flow what approach can I take. Because with the fuse in and I touched the pins there were 0 volts on each pins with it in. I'm just asking cause when it does come Monday I know where to start at already. Do I start unplugging stuff.
I feel like we are getting, a little, off track. Measuring a voltage drop across a fuse is a method better used for identifying which circuit is responsible for a parasitic draw. Very small amounts of current. I mentioned it in this application, simply, to give you an easy way to make a comparison. I am curious to see if there is a base current draw.
We are looking for EXCESSIVE current flow. The fuse protecting that circuit is rated at 7.5 amps. If it was blown, it exceeded that. To measure this kind of amperage, the multi-meter will, probably, need to be set on VOLTS DC, not MILLI-volts. If we were looking for a parasitic draw, we would start unplugging things, and look for the voltage drop to go away. We are not looking for a parasitic draw. Instead of unplugging things, you need to do just the opposite. Turn them on. Windows up. Windows down. Wiggle the wiring harness. Flex the connectors. Bounce up and down on the care. Open and shut the door. All the while, monitoring the current flow/voltage drop. Watch for spikes. If you can MAKE the fuse blow, you're getting close.
Jay2034 wrote: Yeah my test lead to a known good ground. In this case to verify I used the ground from my power probe just to be sure I had a good ground. With the negative lead on ground and positive touching each pin on the fuse with it in the box is zero volts.
That changes things, a bit. Do you have an incandescent test light?
- Jay2034
- Jay2034
With the fuse pushed all the way in, you said you read 0 volts? You think it is being pulled to ground? With the test light connected to battery Positive, touch the fuse test points. Does it light the test light?
- Jay2034
- Jay2034
Jay2034 wrote: I'm thinking this fuse box is bad inside.
I am thinking the same thing. If it turns out that you are losing voltage inside the box, before the fuse, my next step would be to take the box apart (disconnecting the battery, of course) and see if I could fix the connection.
- Wmurky
It's easy for them to sit in there chair behind her desk come out every once in awhile and go what the fuck is taking so long pardon my French but I know exactly how you feel that's pretty typical with a lot of bosses they soon lose the memory of what it's like to be under the gun and trying to figure stuff out with little or no helpJay2034 wrote: Hey what's going on guys. I'm new to this forum and been a member of the premium channel. But if anybody has suggestions for me or has done it before or resources I can go to to get better at reading wiring diagrams. I have 4 months of this engine diagnostics and honestly it's going pretty well at the shop. But the shop is very limited in resources as far as scope equipment or guys in the shop with knowledge. We have alldata but I see michell has better diagrams when Paul uses them. But this 04 bmw wiring diagrams for the window power switch is really tough to dissect with a bunch of wires it has on it and really nailing which wire to send 12 volts or ground it. Bosses don't understand that. They just say how can't u figure out how to put the window up. Mind u I'm the youngest guy in the shop and the guys with 30 or 40 years of experience can't figure it out either. It's just frustrating with the pressure and the lack of resource we have there and really no one to turn to as far as other techs because they are just parts changers and throw parts and after three parts thrown at it then the fourth one is the problem. And the bosses don't care because they see money coming in but it is biting them in the butt with all the comebacks these guys are having and then the boss throws it at me and expects me to figure it out. It's just really frustrating and I don't mind the challenge but if anybody knows of resources,books, training courses, or something i would greatly appreciate it. I'm studying everyday even when I come home from work. Paul is the best teacher I've had and really grateful to be part of his premium channel. Thank u guys. By the way I live in new jersey just in case if anybody knows anything in my area. And who knows maybe I can meet some of u guys if ur from around here and become good friends and help each other out when we have problems. Thank u and God bless all of u
Sent from my XT1575 using Tapatalk
