Ignition primary VS ignition Voltage
  • bjørn.ali.stokman
  • bjørn.ali.stokman's Avatar Topic Author
4 years 5 months ago - 4 years 5 months ago #56419 by bjørn.ali.stokman
Ignition primary VS ignition Voltage was created by bjørn.ali.stokman
Hey Everyone!
Honda ek4 1997
B16A2
I could really use some help on explaining this waveform. As far as i can see and what i have gotten info from other, this is current limiting happening. However there is no current limiting happening. Full disclosure, I am really new to this, trying to learn.
This is only one example.
It seems my psdata file is too big to upload.
Parts cannon first, then diag.
Last edit: 4 years 5 months ago by bjørn.ali.stokman.
4 years 5 months ago #56421 by Matt T
Replied by Matt T on topic Ignition primary VS ignition Voltage
Red trace looks like normal primary current, other than being upside down. With no limiting. Everything looks good other than the amp clamp being hooked on backwards.
  • bjørn.ali.stokman
4 years 5 months ago #56422 by bjørn.ali.stokman
Replied by bjørn.ali.stokman on topic Ignition primary VS ignition Voltage
Then what is the voltage drop on voltage primary?
4 years 5 months ago #56423 by Matt T
You mean voltage drop increasing with current? That's normal. It does kinda look like it jumps near the cursor line in your second pic but that's probably your 'scope. 8 bit vertical with a 20:1 attenuator?
  • bjørn.ali.stokman
4 years 5 months ago #56424 by bjørn.ali.stokman
10:1 and 9.5 bit vertical.
John Gillespie mentioned in Facebook group that this is because of impedance dropping?
Do you know of any resources I could read up on the theory if this?
Or anything to watch?
Preferably related to this subject.
