Silverado Injector Current
  • Hoinkis
  • Hoinkis's Avatar Topic Author
4 years 7 months ago - 4 years 7 months ago #54855 by Hoinkis
Silverado Injector Current was created by Hoinkis
I decided to grab a current ramp waveform on a 2018 Silverado 2500 6.0 while it was in the shop (no engine issues). I put a fused loop in at fuse 44 (INJ A). This is the fuse for injectors 1, 3, 5, 7. The resulting waveform I got confuses me. I have good looking ramps for the odd injectors as expected. I also have very high current ramps from the even injectors on this waveform, even though they shouldn't be on this fuse. I am pretty new to using lab scopes, so maybe there's a simple explanation. Anyone able to give me some insight? Attached is a Pico 6 file and a pic of the related wiring diagram.
File Attachment:
File Name: 2018Silver...r.psdata
File Size:758 KB
Edit: I'm not sure I'm linking the pico file correctly. Here is a PDF of the waveform
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Last edit: 4 years 7 months ago by Hoinkis.
4 years 7 months ago #54858 by Tyler
Replied by Tyler on topic Silverado Injector Current
Hey Hoinkis! What that particular OE diagram doesn't show is that INJ A also feeds the odd numbered ignition coils. ;) Those are the high current ramps you're seeing. This diagram (Document ID #4694402) shows the relationship:
  • Hoinkis
4 years 7 months ago #54860 by Hoinkis
Replied by Hoinkis on topic Silverado Injector Current
Now I’m mad I didn’t also get a secondary ignition voltage to show that. I’m kind of hoping that truck is still in the lot when I get in tomorrow. I’m still a little puzzled by it though. The order of the low vs high ramps matches up with the firing order which is why I was thinking it had something to do with the even injectors.
4 years 7 months ago #55093 by Joshasta
Replied by Joshasta on topic Silverado Injector Current
This is a 2009 GMC Sierra 2500 6L. First Pic is Fuse 24 and 13 all coil and injector feed with amp clamp reading and sync #1. Second pic is just fuse 24 for coil and injector feed #1,3,5,7 and #1 sync. And the last 2 pics are weird because they seem to be showing abnormalities but the vehicle is running fine. must be user error. Did you get any pics of more your 2018?
  • Hoinkis
4 years 7 months ago #55102 by Hoinkis
The truck was gone when I got in the next day, but I had another one in the shop yesterday. I checked it with a secondary ignition pickup on #1 plug wire and confirmed what Tyler had said. I didn’t save the waveform though
4 years 7 months ago #55125 by Tyler
Which anomalies were you seeing in your captures?
