which pico kit to buy for automotive diagnostic tech?
  • YOTA MDT
  • YOTA MDT's Avatar Topic Author
5 years 1 month ago #51697 by YOTA MDT
Ready to pull the trigger on a 4425 A kit since I already have the Autel ultra scanner with 4 channel scope , And a Verus pro. But is the master diag kit worth the extra 2800.00 over the kit below it for around 4000.00? Looks like the main difference is you get the pressure transducer. Is the pico transducer that much better than other brands? Any thoughts from you guys ? thanks
5 years 1 month ago #51712 by juergen.scholl
Replied by juergen.scholl on topic which pico kit to buy for automotive diagnostic tech?
It´s not only the WPS kit, there is also the OBD break-out box, the additional current clamp and a bunch of different leads and probes.
It comes down to your needs and to which diagnostic tools you already may have....
As you already know the WPS actually is so much more than just one ordinary transducer given its capacities and the accessories that are include. You may consider buying the advanced kit + the WPS kit separately and you´ll save some $ compared to the master kit.
There is a chinese WPS clone out there that works very similiar to the original unit, at a fraction of the cost. Search the forum for it as there already was discussion about it.
5 years 1 month ago #51715 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic which pico kit to buy for automotive diagnostic tech?
Pico is the Dusenberg of automotive scopes and the WPS is simply best,  but  it really boils down to you get enough work that needs it and  can you justify it ?
