Alternator Current and Voltage test on Hantek 1008C
  • allenp
  • allenp's Avatar Topic Author
5 years 3 months ago #50102 by allenp
Hello,
is it possible to test alternator current using CC650 current clamp connected to battery side cable instead of alternator side?
I'm asking because I can't neither see nor approach alternator cable since it's deep inside engine bay underneath intake manifold and other cables and pipes...
Second, how do you test alternator voltage correctly using this scope? What settings in the scope do I need and which cable goes to what on the car/alternator?
Thanks,
I'm just a rookie, just started using this scope, I've never used one since high school where I wasn't paying much attention to it....
5 years 3 months ago #50104 by juergen.scholl
Replied by juergen.scholl on topic Alternator Current and Voltage test on Hantek 1008C
Yes, you can measure the current output/amps of the alternator at the battery or any other location within the circuit. This is possible because the current flow is the same throughout the whole circuit. You just have to make sure to put your clamp around ONLY the alternator's output cable.
To measure alternator output voltage connect the probe of your scope to the B+ post/stud of the alternator and the ground directly to the alternator's case/housing.
Time to create page: 0.258 seconds
