Cheaper (much !) WPS 500
- Wightscope
- Thank you received: 30
5 years 3 months ago - 5 years 3 months ago #49912
by Wightscope
Cheaper (much !) WPS 500 was created by Wightscope
Saw this
www.aliexpress.com/item/4001198287616.ht....32143c00seuCBx&mp=1
a JH-APT-100 looks good, then I found that Dave Sterl had bought one and tested it. Nothing wrong with the results he was getting and it even works with the Pico pre-sets.
Last edit: 5 years 3 months ago by Wightscope.
- juergen.scholl
- Active partschanger
- Thank you received: 462
5 years 3 months ago #49999
by juergen.scholl
Replied by juergen.scholl on topic Cheaper (much !) WPS 500
Three months ago I got one of those, from AliExpress.....
When using it for the first time it didn't work as designed, the pressure just ramped up and didn't change dynamically.
Reason was a tiny plug within the compression hose fitting....Once drilled that out it started working flawlessly.
5 years 3 months ago #50035
Replied by Tyler on topic Cheaper (much !) WPS 500
I've got a coworker interested in a WPS500. Would you recommend this in place of genuine Pico, Juergen?
- juergen.scholl
5 years 3 months ago #50037
by juergen.scholl
Yes, I would recommend it, using it basically for in-cylinder, intake and exhaust readings. Using a Pico Automotive scope you can select the WPS as a preset and the scaling/output is just the same.
Nevertheless, some observations:
The quick fitting and coupler connecting the hose to the sensor is a cumbersome size, you would have to make up some kind of workaround if you wanted to use some accessories like a flowmeter etc.
I don't know if this device is really fluid proofed as the WPS is.
Regarding the long run: time will tell but it's a really solid built. I like the easy battery access (18600), just in case one day you'll have to change it.
5 years 3 months ago #50075
Thanks, sir.
I'll follow up in here if one of us pulls the trigger.
