gm ls engine ignition secondary wave form
  • Nowing75
  • Nowing75's Avatar Topic Author
6 years 1 month ago #43071 by Nowing75
I was looking at an 08 we have just playing with the new scope. My secondary wave is nothing like what most of the ones i have looked at are. it does not define the dwell its just a curve. thanks Jason
6 years 1 month ago #43141 by juergen.scholl
Replied by juergen.scholl on topic gm ls engine ignition secondary wave form
Do you have a pic to share with? What kind of probe did you use?
  • Nowing75
6 years 1 month ago #43154 by Nowing75
Replied by Nowing75 on topic gm ls engine ignition secondary wave form
I will get one tomorrow. I was using the inductive pick up from snapon
6 years 1 month ago #43156 by Matt T
Replied by Matt T on topic gm ls engine ignition secondary wave form
Nowing75 wrote: I will get one tomorrow. I was using the inductive pick up from snapon
Sounds like you've got an inductive RPM/trigger pickup. They're designed to output a signal when the plug fires not a secondary ignition waveform. Yellow trace below is what I get from my MAC one.
  • Nowing75
6 years 1 month ago #43206 by Nowing75
I guess it’s not called inductive it’s the one for secondary waveforms. I took one of our Buick and it looked like what I’m used to seeing. Thanks for your reply.
  • Nowing75
6 years 1 month ago #43207 by Nowing75
I just got Paul’s book so I will have to do some reading.
