Secondary paddles
  • Jonathan Haffer
  • Jonathan Haffer's Avatar Topic Author
6 years 3 months ago #41232 by Jonathan Haffer
Secondary paddles was created by Jonathan Haffer
I couldn’t get a good waveform no matter how I set my scales, any suggestions?
Jonathan Haffer
6 years 3 months ago #41242 by Tyler
Replied by Tyler on topic Secondary paddles
What paddle were you using?
You're on a Toyota COP, it appears, which are notoriously difficult to test with a secondary pickup. :( Strange as it sounds, but you may have better luck with just an alligator clip. Here's a couple threads worth reading:
www.scannerdanner.com/forum/diagnostic-t...secondary-probe.html
www.scannerdanner.com/forum/lab-scope-di...need-to-buy-one.html
The following user(s) said Thank You: Jonathan Haffer
  • Jonathan Haffer
6 years 3 months ago #41246 by Jonathan Haffer
Replied by Jonathan Haffer on topic Secondary paddles
I saw we’re you helped a guy on how to build a secondary paddle out of a old Honda distributor, I have a distributor off a 2000 crv 2.0 , would that work and if so could you link me to the instructions how, I would really appreciate that
Jonathan Haffer
6 years 3 months ago #41256 by Tyler
I see no reason why that wouldn't work! :cheer: It will probably only have one or two pickups (VRS sensors) in it, as opposed to the three you'd get in an older distributor. But really, you only end up using two at a time anyway.
There's no instructions to link to. It comes down to fishing the pickups out of the distributor, then grinding enough plastic off the outside to remove the mounting bracket and magnet. You're left with the pickup coil itself and the wires connected to it. Connect one end to a scope channel, and the other to ground. I'll try to grab a picture of mine at work tomorrow.
I will say that the wires are quite thin, and in your case, 20 years old. :lol: They have a tendency to break if they're not braced/secured. A setup like Noah's will stop the wires from flexing too much.
The following user(s) said Thank You: al514
  • Jonathan Haffer
6 years 3 months ago #41257 by Jonathan Haffer
Ok, I saw what you was talking about with the wires so small, I’m a New tech at Toyota, I just finished SD’s whole online class, I thoroughly went through the classes for the past year, I also bought a used verus and have been practicing with the scope, Toyota hired me and to my amazement no one uses a scope there, I got the chance the other day to break mine out , but you saw the horrible capture I got, I’m determined to be the first guy in the shop to know how to use a scope effectively,
Jonathan Haffer
6 years 3 months ago #41271 by Tyler
You can do eeeeeeet! :cheer:
Here's what mine looks like. Not elegant, I know.
  • Jonathan Haffer
6 years 3 months ago #41273 by Jonathan Haffer
This is what mine looks like, it looks a little different than yours
Jonathan Haffer
6 years 3 months ago #41299 by Tyler
Good to know Honda the exact same pickup for years and years. :silly:
The magnet is still in there, so start grinding on the end furthest from the wires. Eventually you'll uncover two Phillips screws that hold the magnet on. Spin them out and you're home free.
  • Jonathan Haffer
6 years 3 months ago - 6 years 3 months ago #41309 by Jonathan Haffer
We’re are you getting them banana plugs ? I ordered these , I couldn’t find the kind you got,
Jonathan Haffer
Last edit: 6 years 3 months ago by Jonathan Haffer.
6 years 3 months ago #41310 by Noah
Replied by Noah on topic Secondary paddles
Here's the one I made if you're interested.
6 years 3 months ago #41319 by Matt T
Replied by Matt T on topic Secondary paddles
Jonathan Haffer wrote: We’re are you getting them banana plugs ? I ordered these , I couldn’t find the kind you got,
"Stackable banana plugs" should pull them up on amazon and ebay. It's either those or "safety banana sockets" you really need for something like that pick-up so you've got a female to plug your test leads into. If you use regular plugs then you'll also need couplers to connect them to your leads.
6 years 3 months ago #41353 by Tyler
Pretty sure I got those from Digikey:
www.digikey.com/en/resources/connectors/...a-and-tip-connectors
Their site is horrible to navigate. :silly: But they have a huge selection of quality stuff to choose from. If you want to be specific, these are the ones I ordered:
www.digikey.com/product-detail/en/cal-te...KCT2631-2-ND/5765511
To be honest, I wouldn't get these again - they're excellent plugs, but the stacking feature isn't needed for the secondary probe.
6 years 3 months ago - 6 years 3 months ago #41531 by al514
Replied by al514 on topic Secondary paddles
Can't you take a look at the primary, isn't the primary supposed to mimic the secondary? I haven't read the whole post so bare with me pls.
Last edit: 6 years 3 months ago by al514. Reason: Just adding
6 years 3 months ago #41533 by Tyler
al514 wrote: Can't you take a look at the primary, isn't the primary supposed to mimic the secondary? I haven't read the whole post so bare with me pls.
Absolutely, as long as it's a two-wire coil. Three wire or more won't have a primary waveform that can be tested without tearing the coil apart. :silly:
