MAF sensor waveform analysis
  • Chad's Avatar Topic Author
6 years 9 months ago #36568 by Chad
MAF sensor waveform analysis was created by Chad
When the throttle plate is closed, there is a big pressure difference between manifold vacuum and atmospheric pressure. When you snap the throttle, the pressure, RAPIDLY, equalizes .
( 1 ) This RAPID in-rush of air is the first rise.
( 2 ) Now, with the pressure equalized, the in-rush of air, drastically, slows down.
( 3 ) Then, as the RPM's rise, air flow rises, again.
www.scannerdanner.com/scannerdanner-prem...-sensors-part-1.html
The following user(s) said Thank You: Noah, Andy.MacFadyen, Monde
6 years 9 months ago #36573 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic MAF sensor waveform analysis
When I was learning to use a scope I found it quite a good exercise first time I captured MAF on one channel and MAP on another.
