Laptop on a budget
- JarheadDiagnostics
- Thank you received: 11
Look for a decent sized hard disc --- not a small hard disc + cloud storage thisis especially important as Windows 10 eats hard disk space for backups and hard disks are now usually soldered to the motherboard and cant be upgraded. I would regard a 64gb SSD hard disk as a minimum.
Don't go for a large screen size as you will want to use inside the car.
For working outside you might also want to extend your internet wifi --- I use networking over mains wifi access point.
- GypsyR
- Thank you received: 27
Tiger Direct (for example) always has a selection of used and refurbished laptops for around $199 that make good work laptops. It's usually very much worth it to get one already loaded with what version of Windows you need. Windows 10 is working for us. Some things will still run on Windows 7.
- Deltron
- Thank you received: 5
Also, a side note, Windows has some release "mode" that doesn't allow any apps other than verified Store apps to be installed. You won't be able to install Pico software if you get that version. I forget what it's called but the salesman should know.
GypsyR wrote: I've become very fond or used/off-lease/refurbished Dells. Once a bit outdated you can get stuff like bargain priced new batteries for them...
Thanks for this advice.
Got my eye on this one:
www.tigerdirect.com/applications/SearchT...p?EdpNo=6598619&Sku=
- GypsyR
