VRS help
- Eduardo
6 days 15 hours ago #93359
by Eduardo
VRS help was created by Eduardo
Hello to all, I need some help with VRS crankshaft sensor
If I have a sensor where I can see the waveform only on one wire and the other wire is ground (see picture)
what kind of signal should I see on the ground wire if the ground wire is cut? (See 2nd picture)
Should i see 0v? Should I see the same waveform as the other wire? Or inverse sine waveform compared to the other wire?
Thanks
Thanks
- Thank you received: 1142
5 days 17 hours ago #93360
Replied by Noah on topic VRS help
That's an interesting question. I suppose the best way to find out would be to cut the wire and scope the signal. I don't think you will see zero volts with the wire snipped and ground removed because typically these sensors generate a voltage on both circuits. I would imagine you would see the inverse of the signal wire because I can seem to recall issues with 2 wire sensors accidentally wired in reverse. I am interested to know what you find.
The following user(s) said Thank You: Eduardo
