Known good waveform
- WrenchWizard88
1 year 1 month ago #92266
by WrenchWizard88
Known good waveform was created by WrenchWizard88
Good morning fam!!! I was diagnosing a 2004 pontiac sunfire with a 2.2l eco and I was wondering if anyone by chance had a known good waveform for ignition. I took a primary ignition and current ramp capture and wanted to see if there was one I can compare to if anyone can assist or point me in the right direction I would appreciate it thank you!.
- Thank you received: 745
1 year 1 month ago #92270
Replied by Chad on topic Known good waveform
Post your captures and what symptoms/problems that you are having, and we'll help you analyze them.
- WrenchWizard88
1 year 3 weeks ago #92355
by WrenchWizard88
Replied by WrenchWizard88 on topic Known good waveform
My apologies for the late reply so I ended up figuring out the issue on the vehicle it ended up being a lot more then just timing some roller rocker arms ended up breaking in half which lead to no compression and timing chain guides where shot as well.
- Thank you received: 1142
1 year 3 weeks ago #92360
Replied by Noah on topic Known good waveform
Oh wow! The only time I have seen broken rocker arms was because valves and pistons made contact after jumping timing.
- WrenchWizard88
6 months 2 weeks ago #92937
by WrenchWizard88
i believe that's exactly what happened there was at least 3 of them broken
