oscilloscope settings
  • am9203623.mughal
  • am9203623.mughal's Avatar Topic Author
1 year 5 months ago #91849 by am9203623.mughal
oscilloscope settings was created by am9203623.mughal
Hello sir, how are you?I have a firinci 1013d oscilloscope۔And the hentak has a low amp clamp.If I have to check the primary ignition current RAM from these two, which voltage should I set?
1 year 5 months ago #91850 by Chad
Replied by Chad on topic oscilloscope settings
I'm not familiar with that scope or amp clamp but, the amp clamp should have a scale printed on it.
Typically, the output of an amp clamp is 100mv per Amp for a 20 Amp setting, and 10mv per Amp for a 60 Amp setting. An ignition coil typically draws 5 to 8 amps. Set the voltage scale of the scope to accommodate up to 10 amps.
For a 100mv/A tool, 100mv x 10A would be 1,000mv, or 1 volt. For a 10mv/A tool, 10mv x 10A would be 100mv. You can set the scope voltage scale to a higher voltage but, that will make the the waveform appear smaller on the scope screen. Setting the scope to a lower voltage scale will make the waveform appear larger on the scope screen.
