Voltage instead of current for relative compression test
- WisdomWarlord
8 years 4 months ago #21712
by WisdomWarlord
Voltage instead of current for relative compression test was created by WisdomWarlord
Has anyone tried setting their scope for a min of something like 8vdc and a max of like 12, and then crank the engine over to see if you get a useful waveform for doi G a relative compression test? Is it a reasonable thing to do if you don't have a current probe? I don't have access to a car with compression problems, so I wouldn't get to see the behavior.
8 years 4 months ago #21717
Replied by Noah on topic Voltage instead of current for relative compression test
Good question!
Voltage measurement is just fine for relative compression testing. Andy has gone over the set up in the past in the forum.
Remember that voltage and current are Inversley proportional, so the valleys of the voltage waveform will be representative of the peaks of an amperage waveform. Many scopes will have a setting to invert the waveform for you.
8 years 4 months ago #21718
Also, you could create a compression problem by removing a spark plug
