Verus Scope Setup Question
- rockp2
- Thank you received: 40
8 years 6 months ago #20219
by rockp2
Verus Scope Setup Question was created by rockp2
I want to set up my Verus scope to use all four channels on a 4-wire GM IAC stepper motor. My question is regarding channel 2. Should I stack the ground wire for that channel on to the channel 1 ground or leave it disconnected and only use the green cable ignoring the black? The reason I ask is because I do not have ground wires for channels 3&4 so I don't know if I should not use it for channel 2 also. Thanks.
8 years 6 months ago #20288
Replied by Tyler on topic Verus Scope Setup Question
You're working with
this kind of test lead
, right?
You're good to leave the ground from the green cable dangling.
Same with channels three and four. Ultimately, as long as the black port on the Verus is connected to a good ground, then all the channels are good to go. No need to stack anything.
The following user(s) said Thank You: rockp2
- rockp2
8 years 6 months ago #20292
by rockp2
Replied by rockp2 on topic Verus Scope Setup Question
Yes, that's the one. Thanks much Tyler!
Time to create page: 0.265 seconds
