Micsig TO1104
- vb4me
- Thank you received: 2
8 years 5 months ago #19119
by vb4me
Micsig TO1104 was created by vb4me
Is anyone using the Micsig TO1104 and if so how have you found it? I purchased one thinking the touch interface would simplify things. I also haven't been able to get a good capture on the few occasions I have tried to use it so far. Seems to jump around a lot. Just after peoples thoughts on the quality and ease of use of the scope?
Cheers
Cheers
- Go4brok
8 years 4 months ago #19891
by Go4brok
Replied by Go4brok on topic Micsig TO1104
Yes I have one and I do like it. However I’m new to lab scopes. I have been able to catch a cylinder comp wave form using a buddies hantek 660 amp clamp. I just don’t understand the probe setting for using different clamps. Got a good signal at 500k setting with a single sweep and it took a picture of the wave for me. Just trying to understand more of the probe settings because there is no easy quick setting for amp clamp or time/volts setting. I just played with it and got a little closer to what I needed to see. Hope this helps. Aloha
The following user(s) said Thank You: vb4me30
Time to create page: 0.212 seconds
