Picoscope 4425 advanced-kit
- kostelectronics
- Thank you received: 7
8 years 8 months ago #17923
by kostelectronics
Picoscope 4425 advanced-kit was created by kostelectronics
Hi everyone!
I've bought a Picoscope advanced kit and played around to learn how to use this Instrument.
I've tryed to measure the starter-current on my own car with the 2000A Amp-Current-Clamp from the kit.
As soon i degauss (Zero) the Amp-Clamp, i got an error, that the current is out of range (too high).
Also i get this error when i measure the starter-current and the waveform is way out on my Screen.
I selected the "2000A Amp-Clamp" in the Software and set the range up to 1000A.
Do i Need to configure the Amp-Clamp in the Software before?
BR Matthias
BR Matthias
8 years 8 months ago #17934
Replied by Andy.MacFadyen on topic Picoscope 4425 advanced-kit
Sounds like you might have a bad clamp as a sanity test have you got a way to connect the BNC to a digital voltmeter ?
- graywave
- Thank you received: 80
8 years 8 months ago - 8 years 8 months ago #18490
by graywave
Replied by graywave on topic Picoscope 4425 advanced-kit
Did you zero the clamp off the wires? I don't think that should matter
Last edit: 8 years 8 months ago by graywave.
The following user(s) said Thank You: kostelectronics
- kostelectronics
8 years 8 months ago #18525
by kostelectronics
Replied by kostelectronics on topic Picoscope 4425 advanced-kit
yes i did. but i realized that this peak is pretty normal, the inside electronics of the clamp cause a very high spike when i degauss the probe. i didn't know this before.
BR Matthias
BR Matthias
- robert.lesaca
- Thank you received: 19
7 years 3 weeks ago #34186
by robert.lesaca
Replied by robert.lesaca on topic Picoscope 4425 advanced-kit
Did you specifically mention/select in the CH that you are in that you are using the 1000 Amp probe?
