Reluctor ring shift, scope test 2010 Cadillac srx 3.0 awd cam/crank test
  • shawnwmoore22
  • shawnwmoore22's Avatar Topic Author
8 years 9 months ago #16724 by shawnwmoore22
Is there a way to check for a Reluctor ring shift on the crank using a picoscope to verify timing vs stretched timing chains?
8 years 9 months ago #16783 by Andy.MacFadyen
The only thing that might give a clue is scoping in-cylinder compression test with ignition and cam & crank. But you would need a known good.
  • shawnwmoore22
8 years 9 months ago #16912 by shawnwmoore22
Ok thank you for replying
8 years 9 months ago #17132 by Tyler
I've often wondered this myself! :cheer: I know this issue is out there, and the only way I've heard of to verify it is to pull the pan and visually inspect the reluctor. :unsure: Like Andy said, I think you'd need a known good CKP/in-cylinder waveform to prove it. Because only the reluctor has moved relative to the crank, the in-cylinder waveform itself shouldn't be affected.
The following user(s) said Thank You: shawnwmoore22
8 years 3 months ago #22356 by Jpilgrim82
I would think in cylinder pressure and ignition while cranking should be enough to see it. During cranking ignition should be close to top dead center of compression. If the reluctor has shifted it should be off enough to put the spark noticeably off.
